1994 John Deere 320 Carb
Glyn Robinson
Hey guys and gals!
Is the carb on my 320 lawn tractor worth rebuilding or just replace? It's never been off the tractor and It will not idle. If there is a rebuild kit for this carb, what is the part number? THANKS!
Hey guys and gals!
The FD590V is still a current engine so the carb is currently available as is the service kit and all individual parts.
However there are differences so we will need to get the full engine number off your engine to provide absolute ( as if that exists ) correct parts numbers.
Kawakasi parts are a lot more expensive than B & S or Kohler parts.
As to if it is able to be fixed, that will depend upon what is wrong.
IF the butterfly holes are flogged oval then it is a replace item.
OTOH if it is just the idle circuit gummed up a simple clean will suffice
