sean'sengines
- May 8, 2011
- 54
So, we bought a new Toro Z4200 zero turn mower because of this. We were tired of this old machine. I'd like to fix it if possible, and then sell it. I'm thinking that it needs piston rings, which I REALLY don't want to do.
What happens is that as soon as you put the engine under any stress, (turn the PTO on, start moving the tractor with the hydro) it bogs down and BLOWS blue smoke like crazy, then won't start cause of all the oil getting into the carb. When this happens, if you have the air filter off, you can see oil come into the carb. What can I do about this to fix it?!
HELP!!!!!
HELP!!!!!
