1980 Lawn-Boy Starter Spring Replacement
I’ve switched to Opti-2 for all my 2-cycle equipment with absolutely no problems.
The reason I ask is .........my original user's manual states "one LB can of oil (8 ozs.) per 2 gallons, OR 8 ozs. of non-LB oil per 1 gallon". The problem is these newer synthetic oils are light years better than the old 1980's LB oil I'm sure. I value your opinion re: this question.
Rocky
I was able to successfully replace my LB starter spring this past weekend due to much advice from RIvets. Thank you. A Teflon(r) spray dry lubricant was used on the spring before the wind-up into the metal tin. Everything now works as it should, and I believe it is important for posters to publish their conclusions so as others can pick-up some key learnings.
Now on to resourcing the ideal modern/synthetic 2-cycle oil due to LB oil being fairly rare.
Rocky
Here's what I use for my 10525's.
