TheSensibleHuman
- May 8, 2020
- Threads
- 1
- 9
Are you talking about the ignition module or the magneto/coil? I don't think the ignition module could be flipped. There's a step or groove in the bottom of the module, where the mounting screw sits. The module wouldn't sit correctly reversed I think.
Though, If you are referring to the magneto, is it possible that it could be reversed?
