Carscw,
Happy to hear your tiller is fixed....Awesome!!!
Yes, I was able to fix mine too, the groove pin . Thank goodness for the groove pin, right? Did you find any damage in the gear box or metal shavings?
When my pin let loose it did quite a bit of damage to the drive gear. My worm gear was fine though.
What I did after replacing the pin, as an extra precaution, is slightly loosen the belt that drives the tines.... then when the tines are under stress... the belt slips over the pulley and squeals, at this point I know to back off a little. I can till pretty deep with this configuration.
Very hard to find parts for these suckers, especially the gear box. My main seals at each side of the tines are shot and leak oil. Not much of a concern though, I just add heavy weight gear oil before each use.
How old is yours? Mine has a manufacture date of 1970. It's 46 years old. It's my fathers... he bought it new. What a great piece of equipment. We don't owe it anything. Has been very good to us. What a workhorse. Wish they still made equipment like this. The motor was replaced with a Briggs back in 1982. Motor is strong too. Just a diaphragm, couple of spark plugs, and an air filter or two over the years.
Just tilled with my beast today. Was thinking about you. These old machines are few and far between.
