Thanks; I found this on Permatex site for this after I posted (duh):Never use any added sealant when replacing head gaskets.
"Not recommended for use on head gaskets or parts in contact with gasoline."
So much for a posting on another place.
I use the Stens ones where possible as they are a lot stronger than the OEM onesIntek head gaskets are dirt cheap
I assume I'll see oil squirting into the chamber on cranking?
WHAT liquid metal goop? JB Weld will melt out. An old wrench once told me that lead wool (used for obsolete plumbing) would work. Never tried it.Yes that is the typical intek blown head gasket
I there is a deep groove it will need to be filled with your favourite liquid metal goop then the whole face smoothed & lapped.
I use a coarse stone followed by a sheet of wet & dry glued to a sheet of glass cut to the size of the wet & dry then flame smoothed on the edges .
The head needs the same treatment, but it is a lot easier to do.
B & S rough finish the heads & blocks deliberately so it grips the gasket like the teeth of a vice but some of them are just too rough and lead to a leak.
I have polished then dead smooth only to find the gasket blows out so I had to fit a solid copper head gasket.
OTOH this particular engine blew a head gasket every season or two so I had to do a couple of gasket replacements under warranty as a head gasket has a full 12 month warranty.
Coppergasketsus have intek head gaskets in a few thicknesses
I only use Devcon or POR 15
Both will make a suitable repair to heads
As for JB weld, 99% advertising hype 1% performance So I never use the stuff.
The trick is to buy from shops that engineers go to not the shops that DIY's go to .
