17.5 hp motor won't start
On guys here we go again
My Intel 17.5 wouldn't run. Found a bent push for and replaced it now it turns over but backfires through the carburetor any ideas
Did you set the valves correctly after you replaced the push rod?
Finding TDC with spark plug removed.
Spark plug may be fouled from backfire.
I think I adjusted values correctly turns over easy so I think it's engaging the compression release
The link took me to a video of a fast go cart cool but didn't help
That's my signature...nothing to do with my posting.
Not necessarily indicative of correct settings.
