17.5 hp motor won't start
Russ2251
Check/Set valve lash. This has already been mentioned.
Nosnow
Engine is model 31c707. Type 0154e1
Nosnow
The link took me to a video of a fast go cart cool but didn't help
shiftsuper175607
On guys here we go again
My Intel 17.5 wouldn't run. Found a bent push for and replaced it now it turns over but backfires through the carburetor any ideas
Did you set the valves correctly after you replaced the push rod?
Finding TDC with spark plug removed.
Spark plug may be fouled from backfire.
Nosnow
I think I adjusted values correctly turns over easy so I think it's engaging the compression release
Russ2251
That's my signature...nothing to do with my posting.
Not necessarily indicative of correct settings.
