The battery keeps draing only when I try to start the mower then recharges a little bit when not trying to start it and all it does is click one time and then nothing I don't think it's the starter. I need help. What's wrong.
http://bsintek.basco.com/BriggsDocumentDisplay/heCyEN8buO1rE3Cvh5kbp796Dq.pdf Page 16 troubleshooting procedures. Take your battery to auto parts store and ask them to load test battery. You might want to call first and see if they charge for this service, they should not. Next make sure all cables and wires are tight and secured and free from corrosion and rust. Let us know if this helps or not.
Is it an electrical problem or is it an engine problem like the engine is not passing compression stroke and you hear click because their isnt enough to turn engine?
Whats the model, type & code?
