16 Hp Opposed Twin worth a rebuild? (402707 0132 07)
Carscw
If the tractor is in good shape and you like it why not just put a engine on it ?
I find mowers all the time for under $100 with good engines.
Sent from my iPhone using LMF
scott47429
just seen one of them on crags list for 60 bucks 16.5 horse needs carb work
silver1
That is a great price. If it was in Reno I could pick it up. Most will not ship as it is heavy.
I rebuilt my carb.
silver1
I have a very limited market. Most are $300 to $600 for older units.
Newer ones are over a grand. Vertical engines are harder to find.
Buckshot 1
:smile: You are Welcome. Rods are still available, std or .020 under. If the crank is the only problem. Have it turned .020 under.
silver1
I know that .20 won't do it. It has a deep pit in it from the rod.
I need to get a flywheel puller and get the block apart to sell it.
LB
Buckshot 1
:smile: Sorry to hear that. Good luck on your parting endever.
