1525 Cub
Shawneebuck
I have a 1525 Cub Cadet. Recently I had some work done to it at the dealer. After I got the mower back and used it the first time I noticed that when I went in went in reverse the blades would disengaged. This never happened before. I contacted the dealer and they said it was a safety feature that should have been working like that all along. I asked where the switch/connection was at so I could disengage it but they are not too helpful, I assume from a liability standpoint. Does anyone know where this switch/connection is located and how do I turn this off? I have over an acre of land with many trees and this is causing me all kinds of issues and more time mowing than I previously had.
Thanks
You will find your manual here "K&T Parts House Lawn Mower Parts and Chain Saw & Trimmer Parts"
The reverse cut out switch is generally a normally open switch usually found under the fender or on some models under the foot boards.As a matter of principal I never tell any one in an open forum to rmove a ***** wire then short out the ****** wires as there is no control over who will see this at a latter date and there are a lot of people with no idea of what they are doing ripping out all of the safety features that had absolutely nothing to do with the problem thay are trying to fix,
