W wulfy Forum Newbie Jan 26, 2011 #1 putting a new crank rod piston in but cant seem to find the timing mark on the crank to the cam gear am i looking wrong ? thank you
K KennyV Lawn Pro Jan 26, 2011 #2 You should find a mark on one of the crank gear teeth... The cam mark is at the web between two of its gear teeth... :smile:KennyV
Briana Lawn Addict Apr 28, 2011 #3 Hello, I have moved your post to the Small Engine & Mower Repair Forum. You will have better luck finding assistance there. :wink: Thanks for joining LawnMowerForum!!!
