It may be something that will require a repair but not a rebuild. It will be highly dependent upon how many hours the engine has on it.
For instance, if something has gone wrong with the valve train but the piston and cylinder are still in good condition, there is no need to tear the engine completely down. Remove the cylinder head, fix the valve and the problem is solved.
