basstracker
can't get gauge wheels to move up or down. does the rod the wheels are mounted to move to the left so you can ajust the height of the mower? do the gauge wheels stay on the ground always?
the ajustment lever won't move over to let the pin out of the ajustment hole.
The lever fits in a bracket which is spring loaded on the pin. If the lever doesn't move I could think the bracket could be full of dirt or it is so rusted that the lever doesn't move on the pin anymore? Yes the lever moves to the left. Maybe you could soak it with a penetrating oil it will free up for you.
someone has weled a piece key stock to the bar that slides to the left to let the pin out. it's welded right against the bracket that holds it to the mowing deck. why would someone do that? was it bad to slide out when you were mowing?
I can't understand why. I still have many of the old wheel horses come into my shop and through the years I never came across that complaint. Is the spring weak or broken? It is a fairly hefty spring. If someone never changed the mower height it could be a farmer fix. I find a lot of the old farmers like to fix things with a welder.
That old Wheel horse with 320 Hr. is just getting broken in. That is when they made Garden Tractors to last. You should be able to still buy parts for it from a Toro dealer.
