reynoldston
- May 23, 2011
- 5,705
I'm not arguing but why on earth is it called an anti dieseling solenoid? It runs on unleaded 87 haha. I'll check to see if there's a wire that looks like it would touch it, because now that you say that it only passes through the bowl and screws into the carb
It has nothing to do with the gas type what so ever. The newer mowers for what ever reason, timing, idle speed, engine design?? after the ignition switch is turned off and no more spark at the spark plug the engine will keep running like a very sick diesel engine and that is why it is called a anti dieseling solenoid.
