t.crawford714
- Jun 7, 2011
- 1
- 13
Ok so I've been lurking and now I need help. I have a fairly new Poulan Pro with a 14.5 Briggs in it. It doesn't stay running after we stop spraying starting fluid. It'll run forever on starting fluid (if it was cheaper I'd just run that instead of gas :laughing I've never really worked on carbs before so I'll end up with more questions but the carb is clean, it's got plenty of gas in the bowl. Why won't it stay running but won't run on gas? Could the spark plug not be burning hot enough? I just need suggestions and I can check. Thanks in advance.
