Oldengineangler
- Aug 30, 2019
- 2
- 4
Hi everyone I'm relatively new to the small engine repair world. Got an issue with a Briggs 10T802 I picked up at the local dump. It was full of water everywhere. I cleared that all out, cleaned out everything, replaced the carb with a new one, started it up and it ran erratically. I re set the governor, got new governor spring. The compression is kinda low, around 65. I redid the valves including grinding the stem a little to get the gaps back to normal and lapping them both. Now it starts easily but runs a little low on the rpms and occasionally misses. The spark plug (new) has the powdery black look of running rich.
Is there any way of adjusting the carb on these? It looks like there's no adjustment available and it runs pretty much wide open throttle. The carb came with a long plastic tube sticking out of one of the holes, is that necessary to keep? It interferes with the air cleaner on mine so I took it off. The old one didn't have one.
