John Fitzgerald
- Aug 22, 2018
- 157
Never grease that type of plastic. It is self lubricating. Grease or oil on it will retain grit and accelerate wear.
Hi guys hope ya'll can help. I have a 2007 Fastrak and has recently been throwing the deck belt when engaging the solenoid/clutch. I re-install the belt and set the spring to the correct length and might be able to disengage and engage 3 times before it does it again. I noticed the deck idler pulley was alittle worn in the groove and slighty loose on the pedestal. I just today got a new idler pulley and new belt and installed them. Engaged and disengaged 3 times and tried another time and the damn thing threw the belt again..Any ideas/suggestions as to why this is happening?? Blades appear to spin evenly under the deck. Can the idler under the engine (Kohler 17) be a problem?? Thanks in advance.
