- May 6, 2010
- Threads
- 51
- 11,419
Also remember since a lot of people that I know of went to full synthetic oil in there newer equipment. push mowers, riding mowers and general outdoor equipment such as log splitters, wood chippers, etc. I would think in the near future manuals or websites can say if you use full synthetic versus conventional oil the filter may play a part in the process. Just throwing that out there for the hell of it.
Probably based on the thought that almost all small engine manufacturers have went to synthetic oils in their branded oil lineup, and some have went exclusive synthetic or synthetic blend oils. And all of the small engine manufacturers base their extended oil change on the "better" oil filter, and use of synthetic olls.Why?
What is your rational for the above opinion?![]()
Most auto manufacturers have went to synthetic oils in their engines and other components straight from the factory. So the push is going full synthetics.
