I just got the Scag Liberty with the Kohler 22hp engine and now have 9 hours on it. I need to change oil and filter, can I use syn oil? Can I use Mobile 1 oil in it? Should I use 10w 40 oil?
Thanks for any suggestions on this, such a great mower.
First of all, you should be adhering to the viscosity that Kohler recommends for that mower, otherwise you may be denied warranty service.  Second, you should NOT be using car oil
in a mower engine, or any small engine that is air-cooled for that matter.  There's a couple of reasons for this.  Small engines are usually air-cooled, so the oil needs to be able to handle
higher temps associated with air-cooled engines. Mowers are especially susceptible to running at higher temps and for longer periods of time.  The oil has to be able to handle high, as well as low
temperatures at start-ups and synthetic oils are GREAT in this area.  Also, small engines in general need high levels of zinc additive in the oil. This additive is essential in protecting small
engines from wear over the long term.  Mobil 1 is an oil designed for water-cooled automobile engines and does not contain zinc due to zinc contamination of catalytic converters.
Stay away from car oils for this reason, and by a good synthetic SMALL-ENGINE OIL.  There's a few good ones out there.  I personally use AMSOIL small-engine oil.  It has a 200 hour change
interval as a bonus.  There a other brands out there, but don't put a cheap oil in a $30,000 machine!
