I took 2 photos using the newest 5/8" x 100" kevlar belt I bought locally.
1.) I am pressing my finger and getting the belt taught and then showing how ( and with no blades engaged ) where it lines up with the midpoint of the smaller idler pulley.
2.) Using a spare small idler pulley, it seems the actual radius is 2" but the belt makes contact at the 1 3/4" point.
a)So an appropriate min. belt length might be 100+ 1 3/4 = 101&3/4" <----- this would fit but be very taught I am guessing, not the best.
b) And for maximum I would say 100" ( this is the belt right now ) + say 2 1/2" = 102&1/2" <--- don't know if this would be too loose?
So some dimension between 101&3/4" AND 102&1/2" seems correct.
