Knock-off oil filters
Skippydiesel
"I hate China for its human rights issues, slave and forced labor, aggressiveness, dumping plastics into the open oceans, unfettered environmental issues, and dumping junk into our markets at a loss to undercut US manufacturers."
Wow!
Do you realise, that what you "hate" is, in a broad sense, pretty much what every "great power" (including the USA) has done/is doing, since at least the the Roman Empire, if not before????
I do not support/condone this behaviour, just suggest that its not exclusive to the Chinese :devilish:
Skippydiesel
To be able to make an informed decision about the performance of a filter, the following link gives you the idea of what may be involved;
Anything less is just speculation :devilish:
liolondio
I've already tried a "made in China" filter instead of a Kawasaki 49065-7010 on my FD731V. Frankly, it does the job, but I don't have too much confidence in the long run. The joint seemed lighter to me, and the metal thinner. For a mower that I want to keep for a long time, I will return to the origin. Sometimes the cheap costs more later…
Do you also want an answer for another topic on the forum? I can help you. 🔧🛠️
