Husky Riding Mower Problem
dexter7590
Engine dies when engage clutch for mower blades. Removed clutch, cleaned, it operaties freely. Replaced spark plug and air filter as routine maintenance. Any ideas? Not sure where to go next. Fuel or electrical?
SeniorCitizen
We can often determine if the culprit is fuel or electrical by temporarily disconnecting the ground (kill) wire located on the engine. This removes all safety switches from the circuit so be careful.
