Titan weed eater
Lohman mows lawns
Recently picked up a old Titan curved shaft weed eater and the throtle trigger is stuck does any one no how a I can get it unstuck
Carscw
Hit it with a hammer
Sent from my iPhone using LMF
Lohman mows lawns
metz12 said:
well how old do you think it is?
70 - 80 I'll try to get a pic asap but I think that little thing on the carb that the throttle cable pulls is stuck or coroded. To the point of were it can't move
metz12
try pb blaster, wd-40 or some sort of lube. then try to stick a screwdriver and attempt to pry it out after you soak it in lube. dont break the throttle switch thing though. do it gently.
