Honda HRX217HXA Grass Door
Griz
The mechanism that controls the door to select mulch or bag is not working. If I move the handle I can see the lever under the mower move but it is not moving the door. I close the door manually, and see there is a fork like lever that appears to attach to the door, but it is not connected. Any suggestions on how to repair?
WELCOME TO LMF!
A user on this forum, robert@honda, will probably have the best answer. I would wait for his response.
Good luck! :smile:
Thanks. It's awkward getting under there. I little knowledge would help.
Griz, on the back of your mower is a serial number in the form of "MXXX-1234567" and if you'll share that, I can look up exact service information for you. I know the Clip Director parts were a little different depending on the serial number....
HRX217HXA. That would be very helpful. Thanks. Just being able to see a diagram.
That's the MODEL number...on the back upper edge of the mower deck should be a silver/black sticker with the SERIAL number, it looks like "MXXX-1234567" (M, three letters, then seven numbers) That's the number I need.
As robert@honda said, this is where the serial number is.
Welcome to LawnMowerForum!
I moved your thread to the Honda forum. :smile:
