Carscw
I use a handheld I find it is easier to get around things. And no straps to adjust if more than one person is going to use it.
You will find out that some on here believe in overkill on blowers and trimmers. If all your doing is blowing off the driveway, walkways , and the decks then why get a blower that will move a car.
Same thing with a trimmer the only reason to have the biggest is if your cutting thick weeds or small trees or just to say you have it.
Then comes what type of service are you going to provide? This will determine what type of mowers you will use.
For my residential yards I ONLY use snapper push mowers and cut a checker board pattern.
And handle a 100% of the yard and charge a lot of $.
On my bank owned homes I use a 46 riding mower. ( cheaper than a ZTR and less parts to break ) cut, edge, trim, blow and leave at $35 each at 20 a day. Have got to where I sub must of them out for $25 to the mow and go guys with the ZTR.
You sound like a man that takes a lot of pride in your own yard. I don't think you would be happy doing the $20 yards just mowing.
I enjoy doing the high end homes where I have total control of the entire yard and they don't mind paying to have yard of the month.
If you take pride and love to show off your skills than this is the way to go.
I do not do contracts at all your work should keep them year after year not a contract.
Anyone can cut grass but it takes skill to groom grass
Sent from my iPhone using LMF
