LT 150 Fuel Pump
Rob518Mar
Hello, newbie here. Lots of good information here. I bought a Lt 150 that is roughly a year old, was on fire mostly cosmetic. I've been told it uses a vacuum fuel punp but I can't find where it is or where it hooks up. I know older models used mechanical pumps but there is no place on the block for one. Any help/diagrams would be greatly appreciated. Thanks.
Please provide engine model numbers. Not all engines used on JD are equipped with fuel pumps.
Rob518Mar
101_3456.jpg photo of where the mechanical pump is supposed to go.
That's where it should be. Apparently your tank is located above the engine and in no need for a pump.
