B Butch1957 Active Member Joined Oct 18, 2011 Messages 59 Nov 27, 2012 #1 On my MS-290 saw it is no longer oiling ? I see nothing that has come loose. Can it be a worm gear or something else major ? Please Respond. Thanks.
lawn mower fanatic Lawn Pro Joined Jun 8, 2012 Messages 6,749 Nov 27, 2012 #2 Hello! Try reading this....it will help: Stihl MS 290 Not oiling - Tree World. Good luck! :smile:
metz12 Well-Known Member Joined Nov 24, 2012 Messages 892 Nov 28, 2012 #3 there is an oiling pump usually located where the bar oil reservoir. it probably got a wood chip in it somehow. give it a cleaning and it should work fine. this is what happened to my buddys husqvarna 345
B Butch1957 Active Member Joined Oct 18, 2011 Messages 59 Nov 28, 2012 #4 Thanks for the input. I will check into it and let you know. lawn mower fanatic said: Hello! Try reading this....it will help: Stihl MS 290 Not oiling - Tree World. Good luck! :smile: Click to expand...
