I am hoping this is the right place!
DCooper323
Just picked up a used Huskee LT4200 today. The solenoid is bad on it. I have been google searching, but havent found much as far as replacing it. where would I be able to find one? 18hp B&S if that matters.
Let me repeat a post from another thread that might just get you the help you need. Please follow it.
Since this is a help forum, it is only fair that the people trying to answer questions have some information to work with, so they can give an accurate answer. This helps them if they need to research parts or service information on your engine or equipment. In the first part of your post please include your engine numbers from the ID tag or stamping and the equipment type and model numbers that are on it. Failure to do this may result in you not receiving any accurate help with your problem.
Many of the tech's that hang out here work in or have there own shops and the first thing they do when they make up a work order on a unit is include the engine and equipment numbers on the work order. Since this technical forum is offered free to the public, it's the least we can ask you to do, so please help all of us out. *So please post the numbers in the new topic you start to ask your question. It should be the first thing you write before beginning your question. :D
With this info, we should be able to get you the proper part number.
nomow
Best go to the source
Find and document model and serial number and go to B&S website (Web search Briggs and Stratton) Most B&S info is available including schematics with partnumbers
