tecumseh 10hp Sears LT 10 carb. and linkage
silver1
I would like to have a picture/drawing of the throttle linkage assy. to this carb.
I may want to purchase a new /rebuilt carb.
Any help would be great. I have owned it for 2weeks now!
If you haven't taken it off yet, take a photo.. or draw it down on paper.
Your photo is showing the throttle/governor link and you should have a spring for it to, has your engine got a air vane governor because you say that the photo that posted up is not like yours so therefore its not mechanical.
You should be able to work it out now by the pic that I have posted.
If you need more info then this, then we need more info from you, like engine/type numbers.
Your # 30 looks similar. I took some more pic. The one shows what I think is the correct setup using a paperclip for reference.
I need help with the serial/type motor plate location. Is it by the spark plug?
Thank you so much for your time.
It looks like I will be parting out my YTV/16 as the motor is broken! The 656cc twin 16hp
has a broken rod
LB
The loop end (pig tail) is where the spring go's on to, if you look at your No 1 photo you will the spring on it.
other link go's between (A) and (B)
No help. I can't find the numbers. The pictures will not open.
The loop end of the link go's on (B Governor arm) and the spring also go's into (onto) the loop.
I'll move them over to the throttle. Is there a part that would go were the spring was mounted now?
Do I only need the wire (see pic) and spring?
How am I ever to find the missing wire from the governor to throttle?
