tecumseh 10hp Sears LT 10 carb. and linkage
silver1
I found the type & serial number for Tecumseh 10hp.
Had to use a mirror to read the numbers.
143-296042 sn= 9045D
A VM-100-157018A maybe?
EngineMan
Part numbers are......
Link Throttle 33860
Link Governor spring 33151
Spring Governor Spec, No 40933k part number 33578
Part numbers are from www.mymowerparts.com 606-678-9623 or 606-561-4983 and are for the VM100-157018A
But remember, Tecumseh went tit's up sometime ago now, so some parts may not be available.
silver1
I'll check it out. thanks.
silver1
Link Throttle 33860
Part numbers are from K&T Parts House Lawn Mower Parts & Chain Saw & Trimmer Parts 606-678-9623 or 606-561-4983 and are for the VM100-157018A
I called today and they do not have any of the parts. I'll need to find a broken motor.
thanks for your help. LB
silver1
I googled the Tecumseh 10 Hp VM100 and found a site in Texas and ordered the parts.
I hope the really have them in stock. I should know later today.
Now on to the throttle cable I need.
LB
silver1
Re: tecumseh 10hp Sears LT 10 carb. and linkage......Done 11/22/12
Link Throttle 33860
Well I have to thanks all for the info.. A special thanks to Partstree.com for all the Tecumseh throttle linkage to make this unit complete. (see Pic's)
LB
real8deal
The loop end (pig tail) is where the spring go's on to, if you look at your No 1 photo you will the spring on it.
other link go's between (A) and (B)
Hey i saw these images and some reason i cant find where the 2 fuel lines go can you give me an image of the fuel line that comes from the gas tank to the carb thanks.
silver1
Two fuel lines? On the 10 Hp. Tecumseh with the tank mounted to the engine, the fuel line comes out the bottom of the tank, and if there is no fuel filter, goes to the Carb. on the back side.
real8deal
Never mind i got that fixed now it just needs the screws adjusted on the carb now. Sounds like a nascar or is that normal?
