exotion said:
			Interesting, You can weed eat around a pole in a half circle there is no need for a full circle. Personally the OEM length is a perfect length can easily get around all obstacles with one or two passes and is easy to control. I have seen a few companies around who do remove them.
I have the mentality that the engineers who designed the machine did everything for a reason.
What does the length have to do with the guard?
And why would you only trim around half the pole?
For 30 years that I know of this  is why they have been removed.
I choose not to remove the guard.
If one of my workers get hurt because a safety device has been removed then I am in trouble
If I sling a Rock into a window with the guard removed I pay for it.
And like you said it is there for a reason.
Sent from my iPhone using LMF
