Small engine carb flooding
bluefitness
This isn't a lawn mower, but I was hoping someone would have some general knowledge regarding small engine carbs. When I start the engine, the engine runs at high rpms and gas dumps out of the overflow. I'm thinking the float needle isn't seating properly. I tried to clean the assembly by spraying carb cleaner into the float and letting it soak overnight. Unfortunately, I can not disassemble the float without the use of an ez out extractor. There are no heads on the bolts.
I'm debating on whether I should purchase a new carb or try removing the bolts and replacing them. Do you think a float stuck in the open position is causing my issues? What else could it be?
bluefitness
I also have a couple more questions regarding carburetor operation. There is a solenoid on one side of the carb that has a needle. It appears that it is energized when the ignition is in the on position. Is this a fuel shutoff valve? Is this used to shut off the engine (stops fuel going through the idle orifice).
On the other side of the carb, there is small assembly with spring and hose. What is the purpose of this assembly?
Here is a link that shows the carb:
http://www.atv4usa.com/UTV150 Parts Catalogue-Small.pdf
Let me repeat a post from another thread that might just get you the help you need. Please follow it.
Since this is a help forum, it is only fair that the people trying to answer questions have some information to work with, so they can give an accurate answer. This helps them if they need to research parts or service information on your engine or equipment. In the first part of your post please include your engine numbers from the ID tag or stamping and the equipment type and model numbers that are on it. Failure to do this may result in you not receiving any accurate help with your problem.
Many of the tech's that hang out here work in or have there own shops and the first thing they do when they make up a work order on a unit is include the engine and equipment numbers on the work order. Since this technical forum is offered free to the public, it's the least we can ask you to do, so please help all of us out. *So please post the numbers in the new topic before you start to ask your question. It should be the first thing you write before beginning your question. :D
Can't offer help without.
Just looked at your website. Don't know of many on the forum work on ATV's. Hope some can help when you post numbers.
Lawnranger
After looking at the carburetor diagram it appears similar to a motorcycle carburetor with the long needle/slide. I would research the price of a new carburetor if the manufacturer makes it so difficult to disassemble.
To answer your question, yes a stuck float could cause the condition you are experiencing. Also, is the a rebuild kit available? Sometimes all you can get are complete assemblies.
bluefitness
No, a rebuild kit is not available. I was going to disassemble it and try to clean it. Do you think I can fix it without replacing the needle? I'm not sure if there is a seat or o-ring.
What is they carb on. To me the diagrams look like those of a small 4-wheeler. Are there any numbers or a name on the carb.
Lawnranger
If no kit is available and you open the carburetor up only to find you need parts such as a sunk float (is that an oxymoron?) or a bad needle/seat then you have only one option. You can certainly try though.
Rivets, I have worked on some of these Chinese made 4 wheelers and it's like most things from China - some good and some bad. Kazuma is the brand that shows up most around here and most of them are average but as bluefitness is finding out, parts are difficult to find locally and have to be purchased online most of the time. I try to stay away from them as much as possible but when friends who bought them for their kids ask me to help them I find it difficult to say no.
bluefitness
It is on a small utility vehicle. There are some numbers, but they are specific to this particular vehicle. It does not cross reference to anything else.
That's why I asked about carb name and numbers. We are a Polaris dealer and the wheeler mechanic has had some (not a lot) of luck using parts from different units as substitutes. May get lucky.
