cutter1429
I have read this entire thread and I was rolling in the floor laughing my butt off :laughing: at all you males, so much so I went to the trouble to set up a user account just to tell WENDY, YOU GO GIRL. You guys beating and cutting and banging and using pullers and bending pulleys and cussing at your mowers and this woman figured out a better way to fix her lawn trackor than you did. I just did it Wendys way and it took me 3 hours with blade replacement and no cussing. Except I used an adjustable 6" wrench to bend the tabs out of the way and I removed the tie rods for ease of access.
So everyone out there, don't remove the pulley, use a small adjustable wrench to bend the tabs away from the pulley to squeeze the belt on and I suggest removing the tie rods to make room for the adj. wrench movement. It is much easier that way. Good luck.
