how do i change the oil on my gx75?
I have a John Deere GX75 & here is where it is, By the right rear tire, look from the top of the tire toward the base of the engine & you will see a little drain valve. Hook a piece of hose to the nozzle, now open the valve with a 10mm wrench, the hose directs the oil away to a drain pan.
:smile:
#14 in the attached drawing is the oil drain vave for the gx 75.
:welcome:
Use a good 30 weight oil as per owner manual. :thumbsup: I change much more often than recommended, cheap insurance.:thumbsup::thumbsup:
