Carburetor rebuild kit John Deere SRX75
Gene123
Where can I get a carburetor rebuild kit for a John Deere SRX75 30" riding mower?
If it is a briggs, kohler, honda, you can get the numbers off the engine and get one from any dealer. If kawasaki they you will have to go to JD.
okiepc
It has to be a Kawasaki & you will have to go to JD
Gene123
Thanks, Okiepc. I just bought the SRX75 Saturday. The ad said "$175, needs some work." Today I tinkered with it a little. You are right --- it is the Kawasaki engine, 9hp (code FC290V-CS10). I drained the oil. It had lots of gasoline in it. I figured the needle and seat failed causing that. Can I just get a new needle and seat? Or, do I have to get the expensive carburetor rebuild kit from JD? Another question: I'm puzzled why I can't see the oil level on the dipstick to come up to normal. I put in one fresh quart, then kept adding and checking. After two quarts were put in, the dipstick still showed only about a quarter inch. Could the previous owner have badly damaged something by running it with gas in the oil? :eek: He said it started smoking, and he turned it off immediately. I know nothing about this mower. :confused2: I need an owners manual and a factory service manual --- was hoping I could download them in the form of a pdf online, but I haven't been able to find them. ..... Found hundreds of pages of Lawn Boy data, though. Old two cycle Lawn Boys are fantastic little machines that last a long, long time.
Gene123
It's nice to see someone with your credentials on the forum, Ilengine. Your helpful advice will be appreciated by many. :thumbsup:
okiepc
I downloaded a complete manual for $9.99, I mean the service shop manual, it has everything. I will look up the site & get back with you.
okiepc
I looked at my service manual & it states the SRX75 oil capacity is 1.16 quarts or 1.1 L, so where is the oil going?:eek:
Gene123
Thanks, okiepc. I stopped at a large JD dealership in McKinney, Tx on the way home after I bought the SRX75. They didn't have the carb kit or manuals for it. They said they could order them. It was much too expensive for me. I'm retired living on a small SS budget. I hope I can get my SRX75 running without spending much. It has become difficult for me to use a push mower. I'm using a lightweight, 19" Lawn Boy. It's great, but I'm feeling my age. Where are you in Oklahoma? I'm in Texas, just about 40 minutes south of the Red River.
Gene123
