Echo bought Shindaiwa many years ago. That is why Shindaiwa (which is great equipment), is out of business.Look at Shindaiwa's lineup.
They are essentially Echo saws that will be a little less expensive.
Professional Chainsaws | Shindaiwa
Shindaiwa's professional chainsaws deliver impressive power, effortless handling, and unparalleled durability.www.shindaiwa-usa.com
Out of business?Echo bought Shindaiwa many years ago. That is why Shindaiwa (which is great equipment), is out of business.
Cheapest on the shelf. UNLESS you are a tree arborist and use the saw daily. Most likely the saw will sit and varnish up the carb before it gets used again.Any advice on what to get
I don't know much about the new Poulan Pro chainsaws. I do know that older models are quite good. I have a PP220 that's been pretty dang good. All it needs is a new ignition module and some attention paid to the stripped out plastic mounting points. The OEM ignition module goes for around $72 plus tax and shipping.Cheapest on the shelf. UNLESS you are a tree arborist and use the saw daily. Most likely the saw will sit and varnish up the carb before it gets used again.
One of the best I've seen are the Poulan store brand saws. Seen several that had great engines just needing a carb diaghram slash rebuild from sitting with no fuel in the carb. Diaphragm dries up and gets stiff and she won't start. Easy rebuild and she is running again.
Oh also the HomeLite branded saws are good. Look on facetrash marketplace for a nice used one.
The older ones are what I was talking about mainly.I do know that older models are quite good.
Shindaiwa and Echo merged in 2008 under the name Yamabiko Corporation. I have not seen a new Shindaiwa product since then in person or at the Equip Expo in Louisville, KY. You are correct, however, Shindaiwa is still sold (according to the internet), and you.I don't know much about the new Poulan Pro chainsaws. I do know that older models are quite good. I have a PP220 that's been pretty dang good. All it needs is a new ignition module and some attention paid to the stripped out plastic mounting points. The OEM ignition module goes for around $72 plus tax and shipping.
Black Friday Deals are already hitting some stores.
Production of Poulan products was supposed to have ended in 2019-2020 model year, with the Husqvarna restructure of ending box store product sales. So I would be sceptical if Poulan and some of the Husqvarna products are not being farmed out to 3rd party licensees. I know the Husqvarna pressure washers sold through Menards are actually JDNA products, along with the several other Briggs product names.Shindaiwa and Echo merged in 2008 under the name Yamabiko Corporation. I have not seen a new Shindaiwa product since then in person or at the Equip Expo in Louisville, KY. You are correct, however, Shindaiwa is still sold (according to the internet), and you.
Poulan is made by Husqvarna, and in my experience, is sub par equipment. Better than Ryobi, which ain’t saying much.
Yeah, some of the entry level Husqvarna chainsaws, sold at big box stores, are likely Chinese made.Production of Poulan products was supposed to have ended in 2019-2020 model year, with the Husqvarna restructure of ending box store product sales. So I would be sceptical if Poulan and some of the Husqvarna products are not being farmed out to 3rd party licensees. I know the Husqvarna pressure washers sold through Menards are actually JDNA products, along with the several other Briggs product names.
