Chain saw advise
I have a TBC340 Tanaka trimmer never had a carb issue still going strong. I always run non ethanol. Bought it new in 2004.
Look at Shindaiwa's lineup.
They are essentially Echo saws that will be a little less expensive.
Echo bought Shindaiwa many years ago. That is why Shindaiwa (which is great equipment), is out of business.
Any advice on what to get
Cheapest on the shelf. UNLESS you are a tree arborist and use the saw daily. Most likely the saw will sit and varnish up the carb before it gets used again.
One of the best I've seen are the Poulan store brand saws. Seen several that had great engines just needing a carb diaghram slash rebuild from sitting with no fuel in the carb. Diaphragm dries up and gets stiff and she won't start. Easy rebuild and she is running again.
Oh also the HomeLite branded saws are good. Look on facetrash marketplace for a nice used one.
I don't know much about the new Poulan Pro chainsaws. I do know that older models are quite good. I have a PP220 that's been pretty dang good. All it needs is a new ignition module and some attention paid to the stripped out plastic mounting points. The OEM ignition module goes for around $72 plus tax and shipping.
Black Friday Deals are already hitting some stores.
