Torque spec
Need torque spec for Briggs 190 cc Lhead to Toro recycler aluminum deck. I've looked everywhere and can't seem to find it. I am getting some noise on a recent rebuild and it sounds like it is coming from the deck or blade. Blade is like 60 ft lbs so I doubt that is it, but the deck bolt torque I found on line and used seemed light, however don't want to strip out the engine case. Sounds like the tip of a blade hitting something but there is nothing to hit unless the engine is moving around on the deck. Have set the morning aside tomorrow to work on it and replace the struts on a 2004 sable wagon. Hate to spend either until midnight tonight or part of tomorrow trying to find the proper spec on the engine to deck torque. Typical 3 bolt setup as I recall.
Took me 15 seconds to find this.....
Hello Sgkent,
Can you narrow down your analysis of piston slap.
Is this the wrist pin or connecting rod?
Thanks,
Doug
hard to say. I listened with both a stethoscope and a long screwdriver. The rap is too high pitched to be a cylinder I think. I know the wristpin circlips were in correctly but that doesn't mean much. Haven't bore-scoped it yet. I replaced the recoil starter and gave the coil more clearance to be sure I wasn't hearing that. It is like someone is rapping on the mower firmly with a piece of steel dowel. All that said, when a motor is new it doesn't have the clearances of an older well run in mower. Run it out of oil like she did, and many things happen including glazing cylinder walls. The wrist pin could have galled a little bit and that would increase piston slap. It has a plastic cam gear so I don't think it is that. Too loud for a valve unless one is sticking but the mower runs fine otherwise. At this point I would buy a new mower but they can't be sold in California excepting battery ones. I have many things EV, but a car and a mower will not be among them ever. I added up parts to undo what she did and the worst case is $600. That is more than a new mower on sale. Trying not to get upset about it, but it does bother me.
Wives, gotta love them , but they will look you right in the eyes and lie about checking the oil knowing full well they did not. Seems they dig in as if it's a "control issue" and become unreasonable. It's hard to see the signs, but they do have a "tell".
If you look at the head of the bolts you are using you should see either hash marks (none, 1, 2, or 3) (SAE) or numbers such as 8.9, 10.9, or 12.9 (metric). For SAE, unmarked or 1 hash mark are grade 3, two marks are grade 5 and 3 marks are grade 8. You can google torque tables for bolts and it will tell you the maximum torque for for the size (diameter) bolt with different values for coarse or fine threads and grade or strength. SAE bolts are measured in threads per inch, metric are measured by the distance in millimeters between threads. The values given are the maximum torque before the threads or bolt starts to fail. Using nyloc nuts or locking nuts will eliminate the loosening of a bolt however they need to be replaced each time they are installed. Torque values can also be obtained for different aluminum but that will vary based on the composition of the aluminum, whether the aluminum has been surface hardened or anodized.
Fat fingered, should be grade 2 not grade 3.
Thank you. I have a generic chart but since these bolts go into aluminum I was a bit concerned about over or under torquing them. Both are hazardous to the lifespan of the threads. I used the generic chart already with some blue Loctite.
