Torque spec
Need torque spec for Briggs 190 cc Lhead to Toro recycler aluminum deck. I've looked everywhere and can't seem to find it. I am getting some noise on a recent rebuild and it sounds like it is coming from the deck or blade. Blade is like 60 ft lbs so I doubt that is it, but the deck bolt torque I found on line and used seemed light, however don't want to strip out the engine case. Sounds like the tip of a blade hitting something but there is nothing to hit unless the engine is moving around on the deck. Have set the morning aside tomorrow to work on it and replace the struts on a 2004 sable wagon. Hate to spend either until midnight tonight or part of tomorrow trying to find the proper spec on the engine to deck torque. Typical 3 bolt setup as I recall.
Took me 15 seconds to find this.....
hard to say. I listened with both a stethoscope and a long screwdriver. The rap is too high pitched to be a cylinder I think. I know the wristpin circlips were in correctly but that doesn't mean much. Haven't bore-scoped it yet. I replaced the recoil starter and gave the coil more clearance to be sure I wasn't hearing that. It is like someone is rapping on the mower firmly with a piece of steel dowel. All that said, when a motor is new it doesn't have the clearances of an older well run in mower. Run it out of oil like she did, and many things happen including glazing cylinder walls. The wrist pin could have galled a little bit and that would increase piston slap. It has a plastic cam gear so I don't think it is that. Too loud for a valve unless one is sticking but the mower runs fine otherwise. At this point I would buy a new mower but they can't be sold in California excepting battery ones. I have many things EV, but a car and a mower will not be among them ever. I added up parts to undo what she did and the worst case is $600. That is more than a new mower on sale. Trying not to get upset about it, but it does bother me.
Wives, gotta love them , but they will look you right in the eyes and lie about checking the oil knowing full well they did not. Seems they dig in as if it's a "control issue" and become unreasonable. It's hard to see the signs, but they do have a "tell".
