Poulan Pro 220
Walbro WT-625 was cleaned and rebuilt.
It will be going on my PP 220 tomorrow, hopefully.
New fuel lines and filter have been installed.
The Ruixing kit did not come with a new bulb. The old one is in good shape. I'll get a new one and be safe.
Update:
The Walbro carb is rebuilt. New fuel lines and spark plug. I pulled and pulled and pulled. No start. I pulled the plug and checked for spark. No spark. 🤬🤬
A new coil is $72 plus tax and shipping.
Many of the plastic mounting points are stripped. After further evaluation, I have decided to replace it. It's 17 years old and parts are getting harder to find. Some are unavailable.
Now, I have to find one of similar power and a 16" bar.
A piece of advice when working Plastite screws. When installing always turn them as if you are removing them until they jump/drop into the threads then tighten. This way you are not cutting news threads which leads to failure of the threads.
And there are some aftermarket coils on eBay under $20.
I think that it was from being apart too many times and over tightening. It's on it's second coil now.
I'm at the point now that I don't want to put any more money into it. It's been a good little saw. For 17 years, numerous storm cleanups, and pruning, I can't complain much.
I'm going to the Echo/Shindawa dealer tomorrow.
