You guys are going to love working on the engine of this one. NOT. This is not repair friendly at all when it comes to engine repairs I need to do.
I got one in with a Briggs 31S blown head gasket. Oil every where. You can't even pull the rocker cover without pulling the engine. Pulling the engine is a heck a lot easier than trying to remove rear frame tube as that route with require unbolting both transaxles and then dropping them to release the tube.
Between the engine, dampers, and deck repairs I just gave the customer a $875 repair estimate and this is with me discounting both the parts and labor for the senior. Both spindle mounts are bent, idler arm worn out, and one idler pulley bad along with chunk of the front left deck missing. Boy her yard got to look really bad when mowed. I am looking at 6+ hours of labor if I run into problems on this 12 yr old mower. Already spent 1.5 hrs just doing the pre-repair estimate.
The question now is she going approved the estimate for the repairs? It be at least Thursday before I know as today I am out of the shop all day attending a customer funeral which always depresses me. I probably will skip the actual burial.
