Hello,
Model 10247 surges continuously. Starts on one pull. I was going to pull the carb and clean it without parts in hand, but saw a replacement carb for this model is around $20 on Amazon.
I’m wondering if these cheap carbs work ok?
Now I’m thinking replace with the cheap carb, then I can rebuild the original over winter. Then swap back or keep the original as a spare.
I only run it 10 to 20 minutes a week for trimming.
This is the cheap carb: https://a.co/d/0gzCdQ9l
If the cheap carbs are no good, does anyone have a line on a rebuild kit? Serial number 220010786.
Edit: add images. I will give it a bath too. I promise.
