Does Anyone Know Where To Get Older Manual Predator Engine?
PGB1
Hi All!
Short Version:
Brother borrowed Wacker plate compactor some years ago. Kohler K91 engine stopped working. He put on a Predator engine, probably around 2018. He returned the compactor to me yesterday. Engine troubles.
Trouble:
I searched for the owner's & parts manual at Harbor Freight. They listed four choices using SKU number to differentiate which engine. My engine does not show any of the skus son HF web site. Do you know where to get older Predator manuals and parts lists?
Thanks For Helping. It is much appreciated and the manual will be helpful while I diagnose this engine & seek parts.
Paul
Engine: Predator 212cc Item 60363
Other Numbers Are Below.
You have a Loncin G210FA engine. Attached is the IPL. The only service manual is for snow engine version otherwise it is for the same engine.
Thank You Very Much, StarTech. I appreciate your help quite a lot. The parts list will be very helpful.
Do you happen to know what the valve clearance is for this engine? That I also couldn't find.
Thanks Again!
Paul
Well if I convert SAE correctly it is .004-.006" IN and .006-.008" EX Also the locking nut is torqued to 85 in-lbs middle f the road setting.
Thank You Again, StarTech.
I apologize, but I forgot to ask if you know the ignition coil clearance to the flywheel & spark plug gap. I looked at the versions of the owner's manual on Harbor Freight site and they varied.
Paul
Coil 0.010"
Plug 0.030"
Both of which are pretty common for small engines
