JustinRaney
037x87 belt install.
How long does this take i may just use the original belt for now.Deck comes off.
Steering gear snap ring and gear removed.
Steering pulled up enough so the drive can removed and install.
Steering shaft lowered into place.
Gear and snap ring installed.
Deck re-attached.
And don't forget to check the steering shaft bearing for excessive wear.
I posted that cause one was labeled murray and then seen their was a seperate mower repair forum area and thought to post their for specific advice. Thanks you can delete this one if youre a moderator.I’ve done a many of these. Length of time needed depends on many things. I’ve done it in 45 minutes, but had one which took nearly 2 hours.
Your expertise.
Tools available
Fasteners frozeng
Are you able to get under easily
Will you have a helper
Are you able to follow directions like this thread.
People making duplicate help requests. STOP
