Cusser
- May 3, 2019
- 261
To me: this is a a big clue. I'd work to find out why, and fix this.The belt does fall off once in a while
Stretch/wear, yes.I have no idea how old the belt is Do the belts stretch out over time ??? Thanks
Deck bearings has nothing to do with drive [motion] problems that would be a separate issue.Could of lost an idler pulley or some other deck bearing. There is a heavy belt tensioning spring on a lot of riders that might of fell off. Most likely in your case simple wear and tear. Look at your parts list for your mower. Check everything drive related.
My bad, so true. Different issue for sure. Had deck on the mind.Deck bearings has nothing to do with drive [motion] problems that would be a separate issue.
