Good morning, I have a Toro ZTR with the Kawasaki fr691v. I went to crank it the other day and it was bellowing white smoke out of the muffler. Oil was not overfilled. After researching it appears as though the head gasket was blown. Also, with it running and smoking when I open the oil field oil was spraying out. I disassembled the engine found very little Carbon on the piston and valves. The cylinders look great. I changed out the head gaskets, cleaned everything and reassembled, set the spacing on the valves, and c
hanged the oil filter and filled to the correct level. It fired right up however is still smoking like a freight train. Any ideas?
