Gord Baker
If it does not fire with Starting Fluid, it is an Electrical problem. Most options have been mentioned. Remove covers and check that the Crankshaft/Flywheel key is not partially spun. Did you blow back into the fuel tank? That Carb shut off Valve on the bottom of the bowl should have an audible CLICK when you turn the key to On. Listen for it.
