I have a ferris IS3100 with 26 LC kawasaki. My son was driving the mower and it just died in the field. I towed it back to my barn and started messing with it. This is what I have done:
Continuity tested switches and all seem good
Checked the PTO and it clicks when pulled
Checked red wire at start from battery 12.5+ volts
Checked relays, one was bad so I replaced both
Checked the fuses, all good there
Checked the volts at the ignition switch and they seem good
Replaced the ignition switch
Replaced the time delay module - ferris mechanic told me this was the issue, it wasn't... lol
New battery
Green on relay terminal 86 would allow mower to crank if I ground it out
If I run a wire from S on the ignition to the location of the yellow wire it will turn over but will not run.
What am I missing?
Pulled the coil kill wires and I can get spark when I ground the green wire in the replay. Magneto is had continuity to ground on off, not grounded on run, but grounded on start (wont send spark to plugs when grounded).
New battery
What am I missing?
