BackyardBrian
How's the project going? Any updates?
Based on what was said here, I think the EFI pump (#593890) is really worth a look. Since you only swapped the lift pump, the main EFI pump could still be the one starving the engine under load. That would explain why it runs fine at first but falls apart the second you put any stress on it. I actually found an aftermarket replacement for that pump out there at a much better price. Not sure if this is what you want. Might be worth checking before heading to the dealer.
